Not sure if anyone else has found the same. But recently on wrapcandy, things are going a little haywire. Trying to select items, change text, move text seems to have been taken over by invisible sources!
It was similar on other programmes but as I use WC most this is where it was noticed more.
I remembered that some updates caused similar instances and have just uninstalled some of the updates (in particular 13/7 ones as this seemed to be when things started happening). It seems to have slightly improved things.
Could, of course, be that something I have downloaded (I get freebies from Design Bundles) causing the problems.
Just wondered if anyone else has had similar problems.
